Hi all,
Can anyone talk me through fitting a forge bleed valve (underbonnet boost controller) to 900 16v turbo, if possible with a couple of pic's ?
Probably really basic..... but so are my skills with a spanner
Cheers
Find the vacuum line that runs to your wastegate actuator (If there are two use the one that connects to the top of the can). Cut the hose and connect each cut end to the SIDE ports of the MBC (the bottom port vents to atmosphere or can be connected to the intake pipe POST MAF [if equipped] and PRE turbo).
Start fully closed (completely clockwise) and verify that your base boost is safe and stable. Start tuning your boost by opening the bleeder in small increments...
