I got the stage one upgrade from my LPT and it's definitely worth it! :cheesy:
Then I added a standard Saab boost gauge from an FPT into my instrument binnacle. It was pretty straightforward bar one bit.
One your LPT there should be a metal nipple on the manifold somewhere near the firewall - it's probably got a plastic shroud on it. Put the hose on this, then remove the aquarium cover and thread the hose through the firewall using the channels provided near the suspension strut top on the driver's side (RHD UK car). Thread the hose back across the car to about where the passenger wiper motor is, and you'll find another nipple to attach to.
Inside the cabin, remove the dash top (quite easy once you work out where that last attachment is if you've got a passenger airbag - it's behind the "SRS" moulding which just levers out). I removed the instrument binnacle and took it apart, substituting my scrapyard FPT boost/temp/fuel gauge for my original LPT one. Refit the needles carefully, or you'll find (as I did ;oops: ) that your fuel gauge reads "optimistically"! Refit the binnacle.
Now the hard part. Run another section of hose from the gauge back to the other side of the nipple that protrudes through this side of the bulkhead. If you don't want to remove the passenger airbag you need to be a bit of a contorsionist and handy with a small mirror, but it's less effort than removing the airbag. Attach to the nipple et voila!
With regard to ECU upgrades, I believe you need to be a bit careful about just swapping them over as if your car has the Saab VSS alarm/immobiliser you might encounter some problems [a boffin will no doubt be along soon to refresh my memory whether that's true or not]. I decided to order the full stage one upgrade and not have to worry about such matters. It took an incompetent like me no time at all to fit.
absgt
1997 9000 2.3 LPT Anniversary auto - stage one
