Hello! We are on the same journey at the same time it seems. Just finished the rear brake pads (paper thin left) and rotors, and the front brake pads (1/3 left) and rotors. With 85k miles on the 1992 900S, the rotors felt etched and lipped on the outer edge, so replacing was the right thing to do! Only took a few more minutes time to do - very simple.
I am also doing the shocks rear and front. Never done it before either. Technically not very complicated. Nut at bottom and nut(s) on top. Biggest thing as mentioned is the bottom bolt not coming out easily especially in the rear. I am saving those for last since getting at the back of that bolt is up inside the support arm. For the front, the bottom nuts come off easy, and sliding the bottom off may take a little work, but should come off fairly easy. I am finding the TOP nut(s) more of the "fun" since the shaft on the shock wants to spin too. I decided to just pull out the Sawzall on the passenger side last night and cut thru the rubber bushing in the wheel well area - careful to align exact and to not let the blade hit the body. 1 minute later the top and bottom separated and the shock now removed. Tonight is working on tightening the top nut. I tried that last night - and the shaft spins then too!! So I will use different tools to hold the top of the shaft steady and then the wrench to turn the nut. Fingers crossed that it will be "easy". The driver's side front seems a LOT harder since the top of the shock is under all the brake lines, etc. One step at a time . . . TTT
