1 - 7 of 7 Posts
Banned
i hope this helps
Screen capture of a page from the WIS, what you get when you do a search by the code. When you go in that way, it does not actually do a reverse lookup of the faults that lead to that fault code.
Could this just be caused by a leaky vacuum line at the FPR(fuel pressure regulator ??? and with $5,000 in modifications......
Or crud build-up at the throttle plate ?
How is the drive-ability ?
Discussion Starter #6
Drivability is ok, The CEL goes on once every tank of petrol, so what I have been doing is just to disconnect the battery to reset the CEL.:lol:
But now I want once for all fix the problem. One of the suggestions i have received is that it could be some problem with oxysensor, would that be possible?
WIS?
Reg
John
I have no idea, then, what this could be.
Maybe the weekly refueling has something to do with it.
Chack out the entire EVAP system... and the gas cap as well..
1 - 7 of 7 Posts
