So, I saw that there was a FAQ about this, but i saw no solution for the fans not coming on. Is there a remedy for this? The car is a 1991 saab 9000 turbo 5 spd :eek: :cry:
If both fans don;t work it is likely relays. However, the temperature switch in the radiator fails fairly often and it might be that neither fan will work if that switch isn't working.
To check the rad switch you can short the terminals and the rad fan shoudl come on. if the engine is hot enough and the AC is on both fans should come on. if not the relays are to blame (fuses are OK I assume!)
What fan?
Blower motor fan, radiator fan, cabin air sensor fan, condenser fan, there are quit a few of them on a 9k.
