I'm working on my girlfriends 2007 9-3 Aero 2.8T and was replacing the fan relay control module and came across something odd...
I pulled a fan control module off a 2007 9-3 2.0 at the junkyard, and everything looked good, until I tried to plug in the connectors. Each plug has a slot that prevents them from being plugged into the wrong fan; the plug & wires that originate from the bottom of the module goes to the passenger side fan, and the plug & wires from the top left (drivers side) of the module go to the drivers side fan. On the replacement fan module, the connectors are the opposite. The connector coming from the bottom will only fit on the drivers side, and the top left connector only fits the passenger side. I tried to connect them but the wires won't reach, so I cut the connectors off and swapped their locations, but don't know if they're now getting the wrong signals or controlled differently.
Also, when I crossed the part numbers on eSaabparts.com, it's showing that both cars take the same fan control module (part# 24418357) but this doesn't make sense since the connectors are flipped. Am I missing something? I'll attach some pics in a bit to better clarify what I'm trying to sort out. Has anyone else encountered this?
