1 - 7 of 7 Posts
Hi all
Yea, just replaced my Drive Belt and A/C Belt:D :D .
Is there a running in period, and why is it still squealling at me, allbeit, not as much?
there is no wearing in period, you put it on and your good too goo, if its squealing try going to your auto store and get some belt dressing, it can be called belt dressing or silicone spray, or you can try WD 40 but go with the belt dressing first
Imran
On these cars, if the belt is squealing, there is something wrong with it. Belt dressing is just a bandaid to cover up the real problem which may be a tired tensioner or a wrong sized belt ;)
or a pulley needs some lubrication ha idk, open up the fender liner and take a look at how all the pulleys are spinning, if anything take the belt off and spin each one by hand and see if there is any resistance
GL
Imran
Never use belt dressing on any modern car. Belt tension is important and once set correctly on initial install there is an automatic tensioner to keep it correct until it breaks.
Always investigate and correct the cause of belt squeal on any modern car. they just don't squeal if all is as it should be.
Proper initial tension on the install of the new belt is important.
Yes, really. Belt dressing is a fancy term for belt lubrication. Older V belts didn't mind slipping a little when you "dressed" them. Modern belts are designed for very long service life and are "serpentine" i.e. designed to bend either way. These belts are designed to run without slipping. It is the slipping that causes the squealing and is an indicator that the belt is wearing out faster than it should. Dressing that belt doesn't stop the slipping it just stops the noise caused by the slipping. In other words, belt dressing just allows the belt to slip smoothly instead of in rapid starts and stops which causes the squealing sound (tires squeal for the same reason and you wouldn't dream of lubricating your tires to stop the noise, and brake pads also squeal for the same reason, rapid sticking and slipping, and you wouldn't lube the brake pads to stop that noise either....).
Never lubricate any belts on a modern car, they will slip.
1 - 7 of 7 Posts
