Been trying to fix the blend doors on my 2004 9-5. I’ve got the codes 08 and 11. Upon inspection of the passenger side, I do not see an issue with the blend door arm or shaft. Everything seems to be in place, no significant cracks, doors move freely when I pull on the aluminum arms. I went to remove the drivers side but was daunted by the obstructions to remove the step motor to see the blend door arm. Additionally, the recirculating motor on drivers side will often run after shutting the car off.
My questions are, is it possible to get a false reading from running the ACC diagnostics? is the recirculation motor impacting the ability of the diagnostics to be correctly determined?
FWIW, the AC blows cold on the passenger side, the drivers side is cold but not as cold as passenger and the passenger side sometimes blows cold from the right vent when the heat is on.
Appreciate the help!
