I recently did an oil change and noticed a faint swirl in the residual oil at the bottom of where the oil filter goes into the engine. I was only able to see it because I had a hard time getting the new filter into it that I needed to use a flashlight to see better. The swirl was on top of the oil and was very very faint. It looked like a swirl you'd see floating on top of a cup of coffee, but again, very very faint. I had to use the flashlight at an angle. If you were looking directly into the hole where the oil filter goes, it looked like the swirl was coming from about 45 degrees and traveling along the wall to about 60 degrees before draining towards the center and down the hole.
Any idea what it could be or what I could test to see where it's coming from? It was more clear than white, but I changed my oil early because I had to replace my valve cover gasket so the oil was a dark tan color rather than black. Maybe the color would have been different if the oil were black. It obviously was some kind of impurity.
Anyway, engine's running fine as far as I can tell. I'm getting 32 mpg on the hwy. Engine temp is consistent. No white or colored exhaust comes out of the tailpipe. My coolant level seems to be in the same place, though I did spot a small leak by the water pump. Nothing more than a sweat drip, at least not yet but I can't imagine the water pump is even letting coolant get into the engine. It doesn't work that way, right?
