Experiencing extreme rough idle, car fails to start 1/5 times, check engine light on.
The problem occurred my on morning drive to school which is 10 mins city driving. The car had been working fine beforehand , never had any idle issues. I noticed that morning while warming up the car I felt a 3-5 misfires , I drove along to school and I was approaching a hill so I gassed it and all of the sudden the engine felt like I was running on 2 cylinders. Heavy misfire and hesitation, it was so bad I had to park the car and catch a ride. I have been using Lucas gas treatment 3 tanks in a row.
However I came back 7 hours later and started the car , ran smooth! Halfway back to the house the car acted up. Towed car to friends house and then...
Upgraded to TD-04, replaced spark plugs,fuel filter,performed engine flush and removed small quantity of sludge,throttle body coolant by pass, new PCV version,installed a new rubber antenna
Started the car, wow amazing performance however after 10 mins of driving the car it stalled,failed to start once,rough idling came back( just as bad as the 1st encounter).
I thought of CPS,MAF,O2 sensors,Throttle Body,DIC,bad gas?
The DIC emits spark as I tested it out by plugging the sparks in and grounding them with a wire, crank and all four cartridges fire. BUT, looking at Chamber #4, there appears to be a small amount of fuel coating the piston left unburnt.
Leave the car alone for a few hours start it back up and it idles fine (in park) until you REV the engine or give it load it goes back to the same issue.
Here is a quick video of proper revving and then a stall and a delayed start with a crank. Notice the noise is engine tap not misfire on the 1st run. http://www.youtube.com/watch?v=Zh9W9EW4nhI
I do not have a code reader at the moment.
What is going on?
What is going on?
