Thank you. The smell comes into cabin when idling at a stop. When the car is on the highway - smell is not a problem. After figuring out how to search I found other posts with the same issue
http://www.saabcentral.com/forums/showthread.php?t=169689
http://www.saabcentral.com/forums/showthread.php?t=166417
http://www.saabcentral.com/forums/showthread.php?t=40415
suggesting a leak (fuel, oil, coolant, etc.) onto ground or engine or exhaust parts; the rubber pipe at the top of the CAM; rubber weather strip under the hood; and a leaky oil pressure sensor (located above the starter dripping onto exhaust).
"breather pipe that goes into the rear of the camshaft cover issue"
"Turned out one of the fuel lines had a drip from where two hoses connect, right by where the oil dipstick is. ...Another area to check is the pump itself."
"a small exhaust leak in the engine compartment, AND a bad rubber gasket around the hood along the back below the windshield. This allows the underhood gasses to work into the air intake for the AC system. If you open the hood and check the gasket/seal you will probably find a bad area."
"the plastic grommit that secures the rubber pipe to the top of the cam cover above the Saab lettering? This is a common breakage"
