1 - 11 of 11 Posts
Hi
2003 9-3 arc convertible
does this car have an evap pressure sensor or only a fuel pressure regilator
Having trouble finding the evap pressure sensor online
red is fuel pressure regulator
Yellow is fuel pressure sensor?
270490
Thanks now I found it but what is this yellow sensor then because I found a kinked wire on it would like to know if related to injectors
Search for 24426679, its the intake pressure sensor (MAP i guess).
And the EVAP pressure (tank pressure) sensor is located at the top of the fuel tank for the 2003 CV, and at the fuel pump for for the sedan and all 2004 up cars.
Discussion Starter #10
This is the yellow sensor:
Could be one of dozens of reasons why now stutters at red line cause on of the electrical leads is kinked and some copper stripped off
I have p0330 code ( think this pressure sensor on top of fuel tank)
CDM might be not working right have to test the pins voltage
Could be a bad coil
I hear it like rapid spitting from under the car doesn’t seem like air just fast as an injector problem and have to let off the gas
so I guess this fuel tank senor and or CDM and this bad wire and bad coil could all be causes
But p0300 can be caused not only by that sensor on tank I presume
New nkg plugs installed today
going to try to solder that wire for more contact tho
1 - 11 of 11 Posts
