Hi,
I have a 9000 Saab 2.3 Aero 5sp manual... Started it up this morning, drove it for about 2 minutes down the road, went inside my parents place, came back out 1 hour later and it would only turn over, I checked the main relay, fuel relay, fuel pump is working... I checked to Check Engine light flashes and they were 5 and 6 which tell me that 5 is the TPS which I can't locate and 6 which is the heated oxygen sensor, can someone help me find the TPS? I had a look on the throttle body the side is a module that can spin right around would this be it?
Thanks in advance.
Thanks in advance.
