I'm replacing the engine in a 2001 2.3 Linear wagon with a 2002 Aero engine (A dealer 'warranty replacement' 4 years ago with 40,000 miles). Here is my checklist, what else should I do to have a trouble free car?
Check List:
- Reseal Engine: Front & Rear Main Seals, Oil Pump O-Ring, Valve Cover gasket, Distributor Seal, CPS O-Ring
- Transmission: Shaft Seals (2) ; Oil pump Seal / Torque Converter Optional / Inspect then decide
- Starter & Alternator rebuild
- Replace Water Pump
- Replace Serpentine Belt, tensioner & Pulleys
- Motor Mounts – How to inspect / Evaluate?
- Hoses – many were replaced in 2009, Check / evaluate others
- (Mitsubishi turbo end play feels ok…)
Other:
- Check Electric fans, Check Brush length, lube?
Check List:
Other:
