1 - 2 of 2 Posts
Help !!!
A 96 SE Turbo is surging at idle....1k-25k up and down.
Checked for any loose vac lines....None found.....Tapped around the IAC and it might settle down for a minute or 2, then continues surging.
While the car is moving, off gear, (engage clutch) the idle will drop to norm.
The fun begins when the car is not moving.....:confused:
Try cleaning the idle air control. Take it off, spray some carburetor cleaner in the openings, shake it around, and pour the excess fluid out
1 - 2 of 2 Posts
