They are a good bit rusty and one has a light coating of oil so I assume it has a pinhole. I can't seem to find new replacements. Should I replace them with Earls braided line? Or maybe I'm looking in the wrong places??
I'm figuring I can tap the holes that are there and use AN fittings but I'm hoping for any easyer fix.
Ebay has them, you can also bring your old lines into most hydraulic shops and they will repair or make a new one usually at less than cost of new.
I have braided line and fitting sitting here so I'm starting to think I might go that rout. Everything under the hood will most likely end up swapped over eventually. I love the look.
