hi there, my 2000 9-3 2.2 tid has 91k. The engine management light keeps coming on when engine gets warm. occasionally it cuts out on me and won't start but when i release the pressure from the radiator reservoir , it starts again. I have cleaned the egr valve as suggested in other threads but still have the same problem.
Just having the CEL aglow is far too vague...We need the emitted code, even then that can be ambiguous, but at least directs the mechanic in the right direction...
Maybe the engine is over heating, but that, IMO, is a silly guess:confused:;oops:
I see no sense nor reason for releasing the coolant pressure at the reservoir, this has no direct effect in the re-starting of the engine.
Is there any loss or consumption of coolant ??
does'nt appear to be any loss of coolant. I know its strange but seems to initially solve the situation.
