Engine hesitations - transmission slipping??
When idling sometimes the car has a hesitation, and then runs a bit rough as you pull away, it seems to clear and go fine. On cruising sometimes it feels like the auto is slipping, trying to change gear, but I haven't been able to figure if it is engine tune. It does have a hesitation under load, like up a steep hill. If it wasn't for sometimes running rough idling I would suspect the transmission.
And a small issue on the soft top, the rubber moulding that mates with the top of the windscreen has folded back in a few places. Is there anyway I can fix this without buying a new rubber strip?
