TD:
Here you go, some speculation, based on the "knocking" noise, and likely similarity between the 9000 engine and my 1996 900SE turbo, now at 108k:
What you are hearing is a loose timing chain, and/or balance chain.
The person who mentioned bearings was half right, the knocking may not be "from" the bearings, but they are not far behind. I just replaced my rod and main bearings, and one of the first signs of trouble was a knocking noise from the timing cover end of the engine. Bearing damage will show up as elevated wear metals if you send a sample of old oil for a UOA (used oil analysis, about $20 at Blackstone Labs or anyone else who does it).
The person who said there is no service interval for the timing chain was also half right, there isn't, but it is very important to check and measure the timing chain tensioner if you hear chain noise, or suspect engine problems. Took me about 45 minutes, and I assume a mechanic can do it in half the time. I checked my EPC CD, and the timing chain tensioner on the 9000 is similar.
The shop that replaced my bearings was expecting a 9-5 with a hole in the block the same day I picked up my car.
My last post on the ng900 board, showing pics of bearing damage:
http://www.saabcentral.com/forums/showthread.php?t=53285
Link to a page showing what I found when I checked my timing chain tensioner:
http://www.geocities.com/ng900set/TC_tensioner/tc_tensioner.html
Good luck.
