1 - 8 of 8 Posts
I was at Saab service and they didn't find any problems.
The car don't make this all the time.
Well, I am not by any means an electrical wizard but if there are no scan codes and it is intermittent I would suspect a short/loose wire. Does it happen only when driving. but not when idling? Only when wipers are on?
Discussion Starter #6
The battery terminals are not lose.
I drive an it just start to do this, can make 30 min or only 1 min, no matter if is raining or not.
The + battery terminal is start to be warm.
Replace battery terminals, they should not be warm.
You could voltage drop test this while the car is running . Turn on all the accessories and put your voltmeter probes between the lead post and pos terminal. I forget the spec but i think its under .3v.
You could wiggle test too .
Or visual for corrosion / acid.
Or feel for heat which you did and was very smart.
(Sometimes i like getting style points for my diagnoses)
I鈥檇 check your batt health for good measure as well.
but Mimmi is right
1 - 8 of 8 Posts
