Yes, it is a classic 900, They used the classic on the convertibles in 94. The problem was gone for a couple of days so I had nothing to look for. Now it's back. When I went to put the top down yesterday it shut the car off. I have also had it happen when the cooling fans come on, also when the pump for the power brakes run in combination with the brake lights. Seems like only heavy loads. So, I looked at the ground at the engine block and almost got the bolt out and it hit's the motor mount before it can be removed. I've had the brake lights out, ignition switch replaced, new battery, alternator is new, cooling fans new, very frustrated.
