On my '93 9000 CDE I have been experiencing some intermittent electrical issues. Wondering if others have had similar experiences and if so hopefully figured out a cure.I have had the car over 2 years but these things just recently started.
1. The lights in the digital clock and digital computer info readout in the instrument cluster randomly go very dim but also, just as randomly, change back to normal brightness.
2. The heater always works well when the car is first started for the day but sometimes after it has been running a while when I restart and drive it only blows cold air until I bump the temperature selector all the way up to high.
3. Occasionally, ie once a month or so, the traction control activated for no reason and the car goes into limp home mode. The ABS light comes on too. I can flutter the gas pedel to keep moving and it lasts until I shut off the car and let it sit a while. We have had snow and ice in the past week and the TCS worked properly.
I'm wondering if it is all related or all are totally unrelated and thinking it might have something to do with corroded connections or loose grounds. Any input from anyone with similar issues would be greatly appreciated.
