The first thing that I would do is to check the voltage at the battery with a voltmeter to make sure that the alternator is chanrging the battery. You should see +13.5 to +14.5 VDC if the alternator is charging.
Unfortunately, the ABS alarm can't be cleared by disconnecting the battery. A dealer will need to do that. On the '99 and later cars, the ABS alarm will reset automatically when the system is repaired.
You might also check your brake fluid; if it's low, that might have caused the ABS alarm... Ron
