Morning all. Well 1 in the AM here...
I have been up to my parents with the family for the weekend. Whilst there I have a mate who runs a breakers. He has at the moment a 1996 900 na. It is a poverty spec model SID1 and no aircon ect. However it does have the later lower arm setup. Basically what you can get at Genuine.
So the question is my mate is willing to drag the 900 out and put the car on its side for me to make access easy to the components.
So the question is...
Do the arms bolt straight on to an early setup like I have or will the subframe have to come along aswell?? Has anybody upgraded the front setup and purchased it from genuine? Did the arms just bolt on?
I know the AR bar and drop links are different but they will come off easy enough.
Also.
Does this year of car have the later slightly larger brake discs up front?
My 94 model has 284 mm discs and the later 96 onwards had 288mm but the hubs were a different diameter so you would have to either turn a couple of mm of the inside of the disc hat to fit my current hubs or remove the hubs and turn the hub down this method needs new bearings upon refitting.
I ask as I can also get the front legs with the hub ect and fit Vectra 300mm discs with long reach bolt on caliper brackerts. As in what Raggy has done. See here
cheers all.
Dead
Also.
cheers all.
Dead
