1 - 12 of 12 Posts
I have long been a VW owner of vr6 and 1.8t engines. I wanted to know if the 01 9-3 vert (my car) necessitates a recirculation of air for the MAF to not throw a code. My vw 1.8t needed it which required a DV. I used a Forge hybrid (004). Are the same model forge products that i use for the VW the same for my car? I sound like a newb because I am. lol. I couldn't find the exact topic of my subject but I did find some good stuff. Also could one of you recommend one to me. I have not remapped the ECU, I just like the sound of course. I'm not planning to mod much. Also, what is the stock psi on my car ? Thanks- Brian
OK. So I can use the Forge 004. I didn't know if that sent enough air back to the MaF or not. I assume the 007 is a good one as well. I wasn't trying to be rude. It just came off that way. Thanks.
Do you own a forge 004 hybrid? Because if you don't you really don't need one,unless there is a problem with yours.The stock bosch is fine for a stock saab.You will not get any more sound from a forge.That is why I posted the link for the open air intake as that will give you more sound from both the turbo and the diverter valve.
1 - 12 of 12 Posts
