I have been following Wulfer's picture help on dropping the sump along with my Haynes manual. I have reached the impossible step. I've tried and tried to raise my motor and the whole car raises not just the motor so I can not get the space to pull out the pan. The pan is loose but there is not room to get it out past the pipe I can feel inside the pan.
Did you take the motor mounts loose? I have my jack under the transmission but I am raising the car, so any suggestions?
Also my exhaust has a big double hanger with rubber attachments on a cross member in front of the flexible section. I do not have the exhaust mount at the back of the pan. Do I need to take that hanger loose. It seems if I could raise the motor that there would be enough room to get the pan out. It is only stuck on the pipe coming down on the inside the oil pan.
