I've had an interesting problem lately. When I go to lower my driver window, the inner mechanism rolls down fine, but the glass stays stuck in the up position, like it's being held there.
I've cleaned/dry-lubed the felt/rubber seals on the sides and top. Didn't help. I tightened the clamp bolts that hold the glass and it helped for a bit, but started slipping out again. I don't want to crank down on those.
When trying to roll down, it's almost as if something is wedging the window in at the top seal. It kind of 'pops' out when it rolls down normally. As I understand it, the glass should be free to move down, right? It actually takes a good amount of wiggling the glass to get it to go down if it comes unclamped from the regulator.
Any ideas or experience with this issue? Does something wear out and pinch the glass in the seals? The regulator is new as of last year.
