Hi guys,
2004 9-3 vert here. My drivers side window takes a few presses to come down but always comes back up on the first press.
the interior lights works on all window switches but doesn’t light up the drivers switch.
I’m assuming new switch pack needed...got The passenger switch replaced 6 months ago.
Am I right assuming it’s the switch pack?
thanks
If you’re handy you can remove the DDM (driver’s door module) after removing the door card) and open it to clean the switch contacts with alcohol. I’ve done it on both my 9-3s and it cured spotty operation. If you decide to replace the DDM I believe it has to be married to the car with Tech 2.
Be careful when you open DDM. If you break tabs, window down will not work properly.
Usually like you showed.
