I'm having an issue with my DDM. I'm able to add it but when I go to Body--> Power Windows and select either driver door or front passenger door I get the following message:
"no systems are available for the selected model year and vehicle/model type"
The part number for the DDM is 12772023 which is supposed to be good for 03-11.
12772023 is for 4D or 5D, not CV.
You have invalid combo selected. Try to add again.
Did you run SPS before add DDM?
Yes...I tried to SPS for the DDM and the PDM and both times it says no need to update since the latest software is in installed. So both the DDM and PDM are the ones that can be added but then can't be changed in the Body settings.
I also have another DDM with the same part number and I get the same results.
Everything works fine...anti-pinch, etc so it's not crucial to get it fixed but who knows down the road.
