does anyone know the torque setting of the drain plug on a manual 99 9-5? thanks
O orinoco · Registered Joined Jun 13, 2004 · 54 Posts Discussion Starter · #1 · May 16, 2005 Only show this user does anyone know the torque setting of the drain plug on a manual 99 9-5? thanks
G Guest · #2 · May 17, 2005 Engine oil drain plug = 25 Nm ~ 18lbf ft Dont forget to use a new washer..
Raven18940 · Registered Joined Feb 13, 2005 · 5,641 Posts #3 · May 17, 2005 Only show this user Do you seriously torque the drain plug?
G Guest · #4 · May 17, 2005 Well I dont. But if you want to do it properly then you should along with most bolts on the car..
O OddyseusDSM · Registered Joined Dec 7, 2004 · 334 Posts #5 · May 17, 2005 Only show this user "Tighten it until it breaks, back it off a 1/4 turn." God I loved Tech. Ed., so much fun.
