I've been battling the seemingly common loss of power in hot ambient temps (especially after car has been parked on short errands) since I bought the car 5 years ago. Better fuel and a do88 intercooler helped a bit but still haven't eliminated the problem. So I've been logging some OBDII data with Torque Pro and the one thing that jumped out at me was my O2 readings:
After car is warmed up, at ~900 rpm idle, the downstream O2 sensor (labeled Bank 1 Sensor 2) shows a perfectly consistent voltage. However, when I hold engine revs at 2000-2500 rpm, it briefly drops off every 5-7 seconds from about 0.7V to 0.1V. It doesn't fluctuate evenly, it can go even 10-12 seconds holding a steady 0.7V before again registering 0.1V for 1 second. Is this normal? And if not, does it point toward a bad sensor? Plugged cat? No CEL ever by the way and no symptoms aside from the loss of power when hot.
Thanks in advance for any help.
