I have a 1985t (3 door) and I was looking at a 1980 (3 door) for parts. I really need some door cards but need some advice. Will these door cards from a 1980 saab work? I know my 85t has a different style of side mirror that goes into the door card a little, should that worry me?
most door trims fit most doors 3for 3dr 5 for 5dr etc, the main problem is if you havea window winder hole in one and you have electric windows, but some did have blanking plugs put in before they had the non hole trims, but if you get a later model trim all you have to do is mahe the appropriate hole in the trim
The 80 won't have the fabric door cards. It's just the plastic composite material all over.
Oh. Yes they fit.
There are fabric panels inside those on models after about 83. I thin of those as the door cards.
