1 - 7 of 7 Posts
I am looking at buying a complete frame with canvas and just swapping out mine vice spend the $1500 to have it done at the local upholstery shop. I will have to take my motors out and put them in the new frame. Does anyone know if I would have to get the top reprogrammed or can I just swap ou tthe parts.
Thanks!
Just swap parts. As long as all the micro switches are installed and working properly, there is no programming needed.
my top completely works like its supposed to now, so I should have all the parts. This top is from a 1996 900S, but the motors and everyhting should be the same, as far as in the frame and such, right?
That should be correct. AFAIK, there were no changes made to the top between 94-97. Maybe 97, but I don't think so.
you will need to make sure the roof on both cars are in the same position IE either open or closed else that will need to be reprogrammed
thanks boxman, I was thinking about that and wondering if I could install the motors while the top was fully up.
1 - 7 of 7 Posts
