Got a 1998 with a navy blue metallic coat of paint (original). Paint is OK but needs to loose old wax layers and several "greasy fingerprints". My plan is to work over the paint with a chemical paint cleaner followed by paint seal.
Question is: should the paint seal contain blue pigment or not? I have been told that metallic paints have a clear top coat - and now I'm in doubt whether to have a neutral paint seal treatment or use the recommended pigment product. Any ideas??
I'm pretty sure that all paints have a clear coat finish.
Banned
Metallic Paints are Usually Clear coat. Non metallics are usually not.
Suggest talking to a decent Body shop before Pouring Chemicals over a basically Good paint job.. Likelyhood of doing V expensive damage is real.
Your Blue paint has got laquer over it, 110%.
If you are blowing in a part of a panel, repair the area first....................
Do not spray the whole panel Blue.
Waft the Blue paint away from the repair
Before doing so Scotch Brite the whole panel with a Grey scotch brite with Gip clean.
Mask up.
Blow the repair in.
Rub off with a tack rag.
Paint whole panel with laquer after about 10 minutes.
Leave overnight
T-Cut panel.
And then wax
GET BACK IF YOU DO NOT UNDERSTAND
REGARDS
ROB BEARD
