1 - 16 of 16 Posts
do you need to remove the spring to change balljoints? all my balljoints are shot. as well as all the bushings. but I will address that later.
thanks
No, just put a spacer between the upper control-arm and the body where the arm passes through the inner fender, This "unloads" the suspension.
Thanks all. I dont need to know how to replace just if I needed to take the springs off first. Thanks again lots of help. Will probably order and change early next week!
An old lug bolt between the upper control arm and the body--one on each side-- worked very well for me to unload the control arms.
Good luck. Not a terribly difficult job. The car is a lot tighter with new ones!
For a spacer....I found a hockey puck works fairly well.
Saab Mad
The metal in that location is does not have a straight top edge. Any flat spacer will crush the metal edge in the centre. That's why the Saab tool has a shape designed to match the shape of the bodywork.
When the edge crushes, paint and underseal are lost which won't help guard against the dreaded driveshaft tunnel rot.
Discussion Starter · #11 ·
Which bushings?
all the suspension bushings
they are 20 years old. I just replaced the alt. bushings and they were so shot. hard as rocks. im sure all the other ones are the same
The alternator bushings live a very "warm" life. Unless they are constructed out of different material to account for the engine/alternator heat they must absorb, I'd say that the suspension bushings might be expected to last a bit longer.
That said, 20 years of use has prolly extracted most of the usefulness out of them......:cheesy:
1 - 16 of 16 Posts
