Hiya can anyone help me , My indicators when I switch them on do not make a noise to let me know that they are working., however they are working. Also when I put Roof down I do not get the Beep to let me know that it has finished,
Kind Regards
Debbie :roll:
Hi Debbie, the SID (SAAB information display - thing above the radio that displays temp, radio station, etc) has a speaker in the back of that has probably either blown or the solder joints broken. You can pull the SID out and remove the case and check (the speaker is about the size of a quarter on the back - opposite side to display - of the circuit board). If the speaker has blown then you can check Radioshack or similar for a replacement.
Thanks
Hiya Thanks for your help will have to get my hubby to have a look. will let you know what I find .
Kind regards
Debbie ;ol;
