Hi there
any of you know a link to a good pictorial of saab 9000 manual transmission disassembly? I think I have seen one or two in the past but they are inactive now.
Or any of you have fixed a problem similar to mine? My manual box started leaking so I removed it. It had virtually lost all the oil through output shaft seal, The output shaft itself has become wobbly, a lot of play in all directions. It must have been a bearing/seal that went inside, in the differential area. Box oherwise fully operational so I`d like to try and fix it. A couple of quickies that would help a lot:
1. What is the fastest way to replace a differential (have a spare box, with bad gears but good differential, plan to swap it).
2. Are differential interchangeable between different boxes of different gear ratio (GM57403 and GMxx103)?
cheers
saab 9k `92 (old style box, 17-teeth input shaft)
