The Turbo is the Main difference, and 35 HP. Linears were 2.0t, Arcs could have been either (I think), Vectors/Aeros were 2.0T until the 2.0T/V6 Aero evolution
G
ARCs are 2.0T only in the USA.
http://saabarchive.com/models/9-3/2003/93SS/specs/index.html
A Garrett GT20 turbocharger is used for the 175-hp engine, with maximum boost pressure set at 0.7 bar or 10.15 psi. A larger Mitsubishi TDO4 unit, operating at 0.85 bar or 12.3 psi, provides boost for the 210-hp version, which also has more aggressive camshafts. Both turbos have integrated by-pass valves.
2.0t 175 hp @ 5,500 rpm 195 lb.-ft @ 2,500 rpm
2.0T 210 hp @ 5,300 rpm 221 lb.-ft @ 2,500 rpm
