I am rebuilding a '95 900 SE Turbo Conv. 2.0L. I have a '97 900 2.0L hatchback parts car. I have found that blinkers, speedometer, emergency flashers, temp gage and radiator fans do not function properly. I think i have determined the ICE is bad. I pulled the ICE 4711263 from the part car and replaced 4536785 ICE on the conv. The blinkers appeared to work. I quick check as I saw some dimming on dash lights when turning on blinkers.
Before I screw something up is there anyone that can tell me is the 4711263 ICE from the 1997 900 is compatible with 1995 ICE 4536785?:
Yes.
4536785 is replaced with 4711263.
Thanks. I assume not concerns to I try it. Just may not function properly?
I can't give you an absolute, but since you could change the body type of the DICE/ICE from Sedan to convertible with a Tech II and not do any damage, I imagine you'd be OK and it will probably run at least. I'd probably be comfortable taking the risk.
How long does it take to get to/remove the ICE?
