1 - 9 of 9 Posts
Do I need to lubricate anything before I reattach the pipe to the turbo with the metal clamp? Can I reuse the copper washer that attaches to the banjo bolt at the top of the pipe?
Slight risk of the o-ring at the turbo un-seating as you secure it. I suppose this could be detected by listening for suction at the joint, or using a spray of soapy water.
Secure the o-ring with Vaseline or similar.
The joint to the turbo and the v-clamp can be assembled from above but easier if you have an accomplice looking at it from below.
Doug
I agree with Doug. Saab recommends lubricating pretty much every o-ring on the car with Vaseline. I've found that it's much easier to get the clamp in place when working from below.
Doug
Doug, not poking fun at you but myself. Whenever I see the word accomplice I think of my best friend of 50 years. We met at age 3 and 4 (me). When we were much younger in the neighborhood that word was applied interchangeably to one or the other.
Just youthful indiscretions, nothing serious you know?.
Aha! I just looked it up and found the word has criminal connotations! Every day's a school-day.....
Doug, that's the best post ever! I laughed for 5 minutes, thank you. You have brightened my day considerably!
And from now on for me it's not that you learn something new everyday but "Every day's a school-day"
Good to know!
Anyway, sort of back to the subject, I was fiddling around replacing some bolts etc. just now and found the screw on the metal clamp needed at least a turn and a half to tighten it. Its well over a year since I last touched it. I wonder whether its loosening for some reason, or whether the angled ends of the clamp, which the screw pulls together, have flexed.
The cobra pipe? Every time I have installed one it was a pain and still seemed a little bit loose at the connection. But never leaked.
1 - 9 of 9 Posts
