1 - 2 of 2 Posts
Anyone know how to remove the plastic peice on the dash that is part of the speaker grille. The plastic on the passenger side rattles at idle and I want to remove it to add some foam underneath. I cant seem to get it out. The secuity led is in the middle.
I actually wanted to do the same on my car today, but running out of time now. I'm not sure if this will help or not, but here's a couple of photo guides to getting in behind the instrument cluster:
http://www.saabcentral.com/~munki/technical/interior/dashboard_insert.htm
http://photo.platonoff.com/Auto/20051105.Saab_NG900_Dashboard_and_Instrument_Cluster/
Although if it's passenger side that's the problem it might just be a case of pulling the glove box out and reaching up under it. I pulled the glove box out of mine a while ago to get to the computer under it and it was quite easy by memory. with the glove box open there's a row of screw under little square pop/flip off covers around the edge.
When I get mine done I'll be doing a photo guide but my buz is on driver side, so might not be exactly what you need.
Andrew
1 - 2 of 2 Posts
