Sorry guys for bothering you again, but I don't have a trustworhy mechanic here. When I mention Saab, they run their *** off (not common car here)... I prefer DIY if it is possible
Is there any backlighting for cabin light switch located near the shift lever?
Is there any backlighting for cigarete lighter hole?
Is there any backlighting for front ashtray?
These are not lit, so I was thinking about changing bulbs. Speaking of which, is there any DIY with changing these bulbs (if they exist) and where can I get them?
My glove compartment light also doesn't work, I tried to replace bulb with one from interior dome light, but still no go. I checked the connections and they seem fine. Trunk light has the same problem. Is it a fuse?
My antenna doesn't come out, I have non stock single slot CD player. Is this his fault? Can he control antenna by default (just connecting it normaly to the car audio connector where stock audio was connected), or I have to do some custom connections?
My windscreen washing is a bit low (low pressure). Is it a motor problem, or I have to check hoses?
My sid warns me of low coolant level sometimes, but coolant is full, can I service that easily?
My fuel gauge is erratic when the tank is full (rarely when it is not) it just drops to zero, and reserve light goes on, and it sudden goes back up, etc...
I already plan to service headlight wipers (they barely move, if they move at all, headlight washing doesn't work also), I found great DIYs
I plan ordering parts online, is it a good choice? Any recomendations for Europe?
I appreciate any help with these things, I'm a bit a perfectionist about things, and previous owner wasn't, so I'm slowly patching up his mistakes
Thanks in advance!
Thanks in advance!
