when i cahnged my clutch I didn't keep track of my vac. line's. now I don't know where to put this vac line that splits into 2. I assume it is for my cruise control because it worked b4 it was disassembled.
Saab Mad
Where is it, in the engine bay or in the cabin compartment?
There's only one CC vacuum line in the engine bay, and it doesn't split, it just plugs in a connector in the firewall. In the cabin compatment there's many CC lines, so "one that splices into two" isn't enough as a description for me....
I just had a look at an owners manual I had laying around... if the line you're talking about is behind the kickpanel, then it must be the one that is supposed to plug into the two switches for the brake/clutch pedals.
the only vac pipe that i can think of that could have been disturbed when removing the gear box is the one that goes from the inlet manifold to a Y connector and then from there to the dump valve and through the faulse bulk head then connects to the fire wall for the boost gauge
