Hi all,
My gf's 1992 900 Turbo sedan normally works fine. I've worked on enough of these to be suspicious of the miles and miles of wire in that thing though, and finally it's thrown me a curveball.
Today the cruise control, turn signals, and tachometer all stopped functioning. It's possible that some other systems are down that I'm unaware of... but the car still runs and drives normally.
Here is the results of my investigation so far:
-no fuses out
-dash turn signal indicators do not work, actual turn signal lights do not work, but the drivers side "cornering light" does work.
-switch feels normal and cancels as normal
-cruise does not seem to have power at all... dash light doesn't come on and it doesn't work at all... previously this system has worked perfectly
I started digging around under the dash, looking for the flasher relay but I couldn't get to it (I'm 6'4" and it's a chore to get under there... I'm sort of familiar with the region having replaced the brake light switch TWICE is as many years)
In my perusal of the Cruise, Turn Signal, and Instrument wiring diagrams, I notice that all three systems share a ground point at G8 which is "behind the instrument panel, on the left". I can't find it at all.
So, anybody have any ideas? Anybody know where G8 ground point is, more exactly? A good method for retrieving the flasher relay?
Thanks in advance,
-no fuses out
Thanks in advance,
