Hi,
very urgent problem with ABS pump. During restoration of my vert I tried to clean ABS system too. I've dismantled its pump motor from pump itself, clean everything, removed pressure container too, even pressure switch. Everything carefully cleaned and mounted back together. And now: motor of this pump works, I can feel, that even pump itself it rotating, but nothing is pumped out... When I try to "push" some fluid into input from a syringe, I can hear, as pump works against some bigger pressure, but still nothing goes out. When I relaese pressure on that syringe, its piston is forced back. Motor can work on one direction only, when You try to exchange wires, it brokes fuse.
Do You have any idea, what it can be? I understand, that there is some oneway valve inside body of pump, because when system is pressurized and pump does not work, You would lost this pressure without some oneway valve. I started thinking about some trapped air inside pump, what means, that pump cannot work without fluid, but I forced some fluid from syringe. maybe it was not enough... maybe I should vacuum this air and replace it with fluid... I really do not know...
So if someone of You met with this problem, help me, please.
