Hey folks and fellow Saab enthusiasts
I’ve had my latest acquisition for around 6 months
Recently it’s been taking longer to warm up and gave me the low coolant light on dash
Having an investigation over the weekend I found a lot of crème caramel lurking in my coolant reservoir and system
That image contains a good couple of litres I’d guess
No surprise they the warning went off as this doesn’t look like it will circulate as nicely as a watery antifreeze blend
The oil cap and dipstick don’t appear to be contaminated
Coolant system hoses are all gunged up with this mess too
Having trawled through the forums for inspiration I’m confused where I should start looking for the culprit here
Some have said check the oil cooler, others have pointed towards the PCV or feed pipes becoming blocked
Any pointers or guidance greatly appreciated
Car is a 56 plate estate that’s has numerous upgrades, but is essentially the B207 engine
Spark plugsOil and filter changed recently using the recommendation from Neo Brothers
Car did have a slight leak from where exhaust meets turbo, just about managed to get it tightened up last week
Other than that haven’t had to do much to it recently
Car is running ok and making good power still
Checked oil and it’s dropped so pretty certain that’s the culprit here
No visible drops of oil on floor under car
Not driving it at the moment but have to drive to Southampton on Saturday for the weekend so could do with getting it sorted before the
Thanks in advance for your words of wisdom
C
