1 - 8 of 8 Posts
Since I'm probably looking at taking out the crank sensor to replace it on my 2.1 sedan, I wondered about the crank pulley oil seal since there's a small oil look apparent at the crank pulley end of the motor. I've never replaced a crank pulley oil seal before. Obvious access is very limited (particularly when working from the top).
Any good/simple approaches? Don't have any special tool nor do I know if a special would work in the space available in-car.
Thanks, craig.
No special tools are needed - just a shallow socket that will fit between the firewall and the crank bolt
I've got one of those - When i did the crank sensor job on my 2.1 hatchback i ground down a socket to make one that would work attached to my breaker bar. i'm asking more about doing the replacement of the oil seal when removing the crank pulley (there's a woodruff key as well I believe?).
Nothing special is needed ... just a few small metric sockets... 10mm IIRC. Remove the housing, replace the seal & o-ring, put it back together,
Make sure the leak isn't coming from the valve cover or timing chain tensioner plug (hidden by A/C compressor bracket) and making it's way down to the bottom of the car.
Discussion Starter #6
As I've not done a crank pulley oil seal replacement before, does just the seal come in/out or is there a sub-assembly or cover plate that holds the seal which needs to be removed as well ?
The seal is on the oil pump cover. Remove the cover, replace the seal, replace the o-ring and put it back together.
I'd search this forum as there are additional threads that go into greater detail on how to perform the work. They were very helpful for me.
1 - 8 of 8 Posts
