my ac compressor clutch isn't kicking on, any ideas ?
also my rke fobs (bananas) only work from arpund 10 feet, is that normal?, does the car take the signal through the radio antenna ? cause i have no antenna
The antenna for the FOBs is in the center console. My all in one remote is about the same. Other people might be able to chime in and give info on how to increase the range.
Have you put a set of gauges on the a/c system? I would first do that and give me the readings and we can go from there.
You can also run a wire from the battery to the A/C clutch connection (red wire on top of the compressor) with the engine off. If you don't hear a solid click as it turns on, you need a clutch coil. If you do hear a click, you have a pressure or control issue.
