In 2000 maybe. The 99 9-3 has 2 pulleys...SPATL said:
In 2000 maybe. The 99 9-3 has 2 pulleys...SPATL said:The 9-3 comes from the factory with the short belt and no center tensioner pully.
There was a mid year VIN # split. My '99 9-3 came shortbelt from the factory(car made in 3/99). Maybe the earlier MY 99's came with the center tensioner.CleveSaab said:In 2000 maybe. The 99 9-3 has 2 pulleys...
My only guess would be that different factories may have done it differently. What is confusing is that, I believe,(ocrrect me if I am wrong Stalker) Stalkers 9-3SE was made in late '98 and had the short belt as well.boxman said:my 98 uk spec 9-3 has the short belt from factory, wouldn't you have thought that the factory would standardize things all at the same time :roll:
Yes, if you have AC.bozza said:...a 6k-2345 is this right.
SPATL said:The best fitting short belt is:
6PK-2460 is the best length for the NG900's
6PK-2345 in the best length for the 9-3's
I measured with the Saab oem pulley, from a Saab dealer. I also have an old one to compare. The marks on top of the tensioner arm are hard to see. The common interpretation is that if the arm is near the end mark all is ok, but it is not. Nobody looks at the clearance.earthworm said:...I can't understand why some have a little trouble with 2460 (needing 2455), yet others can get away with 2470. Maybe the method of measuring varies, or the replacement pulley may be slightly larger/smaller, or a replacement alternator had a different sized pulley...
