1 - 7 of 7 Posts
I received my Tech2 and I have an older laptop that used to run Win7. Where can I find a copy of WinXP to run TIS? Thanks in advance.
FYI:
I successfully loaded Global TIS and TIS2000 using Windows 7 (32 Bit version) with no changes to the instructions for installation shown in the "official Tech 2 Clone thread".
There was no need to install Windows XP.
It works just fine using Windows Seven, and I got Security Access with no problems.
FYI:
Interesting. Do you have a serial port on your machine or can you use USB to x to y?
I used a Belkin F5U257 Serial to usb adapter on an ancient Toshiba Satellite Laptop.
I'm mostly a dinosaur when it comes being up to date on the workings PC's, so all I did was read over the instructions in the clone thread several times and work methodically when I did the installation.
GlobalTIS runs on Windows 10 32 bit with USB serial adapter. TIS2000 will not work but there is no need since GT works with no issues.
1 - 7 of 7 Posts
